Multiple points export in fluent
Hello everyone! When I finish my calculation,I need to creat 100 points and export these points pressure values. How can I do that automaticlly? I hope someone can help me, thx!!
Surface and volum monitor are the best to achieve those points? Why did you select 100 point ? what does it stand for? |
Thank you for your reply ! I am doing a 2d、steady simuation of cascades. After finish, I want to know some points pressure value in the flow field. So I need to creat some points, now I can create them by Tui, but I dont know how to export them automatically... |
you can clearly see those values which points have in PP (Post-processing), giving a probe,
Did you define those points in any boundary conditions? if it is yes, then you find it the value regarding point(s) after calculation completes. (any face has been defined in bc, it means you already know this. if those are not in BC, probe one is proper choice, (or split regarind geometry (faces) that is intersecting those points) |
