void fraction? volume fraction?
Like Tree1Likes
  • 1 Post By tacaro
Old   June 4, 2010, 07:18
Thumbs up void fraction? volume fraction?
tacaro
tacaro is on a distinguished road
Two phase pipe flow is ofter featured with "void fraction" in the open literature.
How does it relate to "volume fraction" value obtained from post-processing function of Fluent?
Thanks
granzer likes this.
tacaro is offline   Reply With Quote
Old   May 20, 2011, 03:35
M. A.
motahar is on a distinguished road
Hi friends,
I'm simulating a tube with water flow.
The tube encounters boiling near the wall.
I intend to calculate 'void fraction versus enthalpy' along the channel.
Can you help me how to calculate void fraction?
I'm in an emergency condition.
Waiting for your comments!!!
Thanks Everybody
motahar is offline   Reply With Quote
Old   May 21, 2011, 08:46
David Stanbridge
swiftaircraft is on a distinguished road
Tacaro, Void Fraction and Volume Fraction are the same
swiftaircraft is offline   Reply With Quote
Old   May 21, 2011, 12:16
M. A.
Hi swiftaircraft,
Yes you're right.
I've worked in single phase for more than 1 year.
But I'm beginner in multiphase flow.
Can you help me how to define multiphase in CFX-Pre?
Thanks
Old   March 3, 2012, 16:29
Default void fraction
kahany
talib is on a distinguished road
depending on your multiphase modulus, you shoud find it under "phase". make sure that you present results for "phase-2"
I hope I helped.
talib is offline   Reply With Quote
Old   March 12, 2012, 02:00
M. A.
Dear Talib,
Thanks for your reply.
Fortunately I could find how to use 2-phase flow in CFX.
But it didn't work well.
I asked a CFX worker and he told me that ANSYS CFX does not support 2-phase.
There are options in CFX-Pre to define the 2-phase, but the software doesn't understand it well.
For example, I'm defining a coolant tube located in a cube made of cu and an armour layer of Carbon on it. The heat flux deposits on the armour layer and then via condution, reaches to the coolant channel (The coolant is water).
By increasing the heat flux up to the 5 MW/m^2, we see phase change in the channel.
When the heat flux reaches 10 MW/m^2, and the coolant velocity is 1 m/s, the temperature is so hot that we have melting of the body. But CFX does not stop running and in CFX-Post I can see the outlet temperature of the coolant is more than 3000 K and obviously all the fluid changes to vapour. But the void fraction analysis yet shows that most of the coolant is yet fluid!!!
I couldn't find any solution for this matter yet.
I would be so thankful if any friend can help me in this issue!!!
Thanks all...
Old   March 15, 2012, 11:32
Default two phase flow
zainab p
zeybi1604 is on a distinguished road
hello.i am actually working on a two phase model having a volume fraction of 0.5316.the problem is that the solution does not converge.can anyone help please?
zeybi1604 is offline   Reply With Quote
Old   March 15, 2012, 12:34
Default not enough info
kahany
hi zeybi1604 , I would be happy to try and assist, but this is not enough information.
please elaborate on your problem (models, geometry, materials, etc.) and how exactly it is not converged. Where is the problem? Is it via mass conservation? maybe only via average void fraction, etc.
Old   March 15, 2012, 13:17
zainab p
thank you for replying Mr Talib. i am doing a multiphase simulation using the mixture model inside a packed bed with the beads being solid inside the bed. the materials inserted are air(primary phase) and fines(secondary phase). the volume fraction for the fines is 0.5316. during the iteration process i get an error message "divergence in AMG solver x momentum". my aim is to find the fines accumulation inside the bed.take care
Old   July 4, 2016, 06:19
bss
Bahador
bss is on a distinguished road
Void Fraction and Volume Fraction are not the same.The gas volume fraction is usually larger than the gas void fraction.
bss is offline   Reply With Quote
Old   October 15, 2016, 12:11
Elias
eliastorca is on a distinguished road
Hello everyone. Bss has reason about volume fraction and void fraction, they are not the same. Actually, I understand from what I read, that the volume fraction is equal to the void fraction only when the two phases (gas and liquid) travel at the same velocity. If my assumption is true the volume fraction represented by Fluent actually is what is called the volumetric void fraction. I'm in the correct assumptions?
eliastorca is offline   Reply With Quote
Old   October 20, 2016, 02:32
Roya.TR
Roya.TR is on a distinguished road
Hi everybody
i'm new in multiphase fluid flow
i want to solve a 4 phases flow (gas-oil- water and sand) in a cyclender.
which methods is better for my simulation?
I want to use eulerian model. is it appropriate?
i chose air as the primary phase but I don't know how define the diameter of liquids.
please help me.
thank you
Roya.TR is offline   Reply With Quote
void fraction, volume fraction
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 10:46
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
