6DOF for moving piston
Old   September 22, 2016, 19:12
Default 6DOF for moving piston
alliche redha
cheredha is on a distinguished road
hello everybody;
i have a problem with 6DOF.
Imagine a cylinder closed by a piston mass (eg 1 kg) and filled with a gas (eg air) . if I let the piston, it will move down.
and it stops if:
the piston weight (p = m.g ) = pressing force ( pressure force = pressure. area)
here is the UDF that I use :
#include "udf.h"
#include "math.h"
DEFINE_SDOF_PROPERTIES(mass_6dof, prop, dt, time, dtime)
prop[SDOF_MASS] = 1;
prop[SDOF_ZERO_TRANS_X] = TRUE;
prop[SDOF_ZERO_TRANS_Y] = FALSE;
prop[SDOF_ZERO_TRANS_Z] = TRUE;
prop[SDOF_ZERO_ROT_X] = TRUE;
prop[SDOF_ZERO_ROT_Y] = TRUE;
prop[SDOF_ZERO_ROT_Z] = TRUE;
prop[SDOF_LOAD_F_Y] = -9.81*1;
the problem is that the piston does not stop
the real case :
my case:
thank you in advance
cheredha is offline   Reply With Quote
6DOF piston amrmoataz Fluent UDF and Scheme Programming 1 April 7, 2016 09:36
one piston dynamic deforming and mesh moving simultaneously john Lu FLUENT 1 June 20, 2014 08:13
Piston Cooling Nozzle Simulation rajeev50588 STAR-CCM+ 1 February 26, 2013 04:41
Piston Simulation helloworld922 Autodesk Simulation CFD 1 September 9, 2012 23:54
Piston stroke cutoff ChesterP FLUENT 7 April 1, 2010 23:58
