User-Defined Memory Allocations for Newman P2D Battery Model
Old   September 26, 2016, 13:08
Default User-Defined Memory Allocations for Newman P2D Battery Model
Seham Shahid
seham.shahid is on a distinguished road
Dear All,
I am trying to do the electrochemical and thermal modeling of Li-ion 18650 cylindrical cells using the Newman P2D Model available in Fluent under the dual-potential MSMD battery models. I am facing a problem when post-processing the results of the simulation.
In the fluent manual under the heading "3.2.8. Postprocessing the Dual potential MSMD battery model" there is a table titled 'User-Defined Memory Allocation' in which there are a total 13 UDMs shown that correspond to various variables. However, when I am postprocessing the results I have a total of 19 UDMs, and I can not figure out which UDM corresponds to which variable. I am specifically looking for 'cell voltage' and 'heat generation rate', so if anyone faced a similar problem or knows from where I can get the values of the cell voltage and heat generation rate then please help me out.
Your response in this regard will be highly appreciated.
Thanks.
seham.shahid is offline   Reply With Quote
Old   September 27, 2016, 02:05
Paritosh Vasava
vasava will become famous soon enough
Have a look at this table.
On the other hand you can use Set_User_Memory_Name to name the UDMIs.
vasava is offline   Reply With Quote
Old   September 30, 2016, 15:49
Seham Shahid
Thanks for your reply Vasava.
In the table there are only 13 UDMs reported, however, I have a total of 19 UDMs. Any idea why is this so?
Old   October 3, 2016, 01:40
Paritosh Vasava
What version of fluent are you using? Are you using CFD-post for post-processing?
Right now, I dont have access to Fluent right now but can you check this meanwhile.
I must say, I have very small amount of experience with MSMD Battery Model.
User Defined Memory Problem Melih FLUENT 17 February 21, 2020 07:43
User Defined Real Gas Model john FLUENT 1 October 25, 2012 14:05
Polyflow Simulation with ViscoElastic Model memory problem sid2909 ANSYS 0 May 10, 2010 05:27
Gradient of a User defined Variable Ramadas CFX 2 August 21, 2007 09:19
User defined memory Hp FLUENT 0 September 24, 2004 00:10
