k-kl-w turbulence model
Like Tree5Likes
  • 1 Post By Chenel
  • 1 Post By Far
  • 3 Post By malv83
Old   September 7, 2009, 19:23
Default k-kl-w turbulence model
Daniel LLanes
PrandtlGlawert is on a distinguished road
Hi everybody,
I´ve just asked some people what could they tell me about the k-kl-w turbulence model and the answer i´ve got is that it´s a kind of turbulence recently released for commercial versions, and that it has been developed specifically for laminar-turbulent transition.
Could somebody tell me something more about that? It would be VERY useful for me, i can find no information on the web about it.
My other problem is that it´s too difficult for me to get a good convergence on that model, but i do have more time to face this problem.
Any website or information about the k-kl-w model?
Thank you in advance people
PrandtlGlawert is offline   Reply With Quote
Old   September 8, 2009, 01:12
denizen is on a distinguished road
you can find comprehensive information in fluent users's guide and theory guide.
regards
denizen is offline   Reply With Quote
Old   September 9, 2009, 14:14
Sean Delfel
delfel is on a distinguished road
I've never used that model, but I imagine that modeling transition to turbulence requires a pretty fine mesh. The fluent user's guide should have the info. about grid requirements.
-sean
delfel is offline   Reply With Quote
Old   September 9, 2009, 15:22
Daniel LLanes
Thx for your replies m8s
Old   November 5, 2009, 10:05
Abraham
Chenel is on a distinguished road
sorry for my English, i looking for information about equations of k-kl-w model. i don´t know if k-kl-omega model is the same that k-kl model. i see fluent user guide but 3 equations model not appears.
thanks you
Jehison123 likes this.
Chenel is offline   Reply With Quote
Old   September 19, 2011, 17:12
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
actually this model is going through the development. first model used the epsilon as turbulent length scale variable. in 2nd phase; model used the omega equation but still epsilon in other two equations. last model, which fluent has I believe, uses the omega equation with omega variable in all other equation.
besides that, there are large changes in other auxiliary equations and limiters (as you there are 24 constants in this model), which are more important to the overall model capability. among them two are very much important : one controls the by pass transition and other controls the natural transition
I can send you all three papers for these three versions.
s.m likes this.
Far is offline   Reply With Quote
Old   September 20, 2013, 05:50
Tamara Annabelle
Marabelle is on a distinguished road
@ Far!
Could you also send them to me? I only found few information to the k-kl-w model and I really want to understand it...
Marabelle is offline   Reply With Quote
Old   September 20, 2013, 10:23
Far
Sijal
email plz......
Old   September 24, 2013, 05:54
Tamara Annabelle
@Far. I sent you a personal message with my emailadress. Thank you very much!
Old   December 1, 2013, 14:40
s.m
saeideh mohamadi
s.m is on a distinguished road
Dear Far, whould you please send me the papers related to k-kl-omega?
i really need som information about it.
here you are, this my email :
saeidehmohamadi@yahoo.com
Thank you very much
s.m is offline   Reply With Quote
Old   March 7, 2014, 12:31
Joao Correia
Monstrobolaxa is on a distinguished road
SO it's been a while since this topic was last discussed.
I've used the k-kl-w and compared computational with experimental surface flow vis. The results match perfectly with transition being predicted within 2% of the wing chord. But I've only be able to compare these results on a few limited cases. Drag and lift are also within 3% of experimental.
Due to issues this turbulence model I've gone back to k-w SST, but am suffering from problems as the forces are now 5%drag and 15%lift off!
With the k-kl-w I've had flow reversal being created at the outlet, which grows and grows. Checking the the turbulence intensity I've found that there is a spot near the outlet where the side wall and moving ground where turbulence is created....leading divergence sometimes or over 1000 faces having reverse flow on the outlet.
My outlet is about 7 body lengths behind the body and upstream of the problematic area turbulence intensity is close to zero.
Anyone suffering from the same? Any miracle solutions?
Monstrobolaxa is offline   Reply With Quote
Old   March 7, 2014, 13:24
Far
Sijal
what problems you are getting with k-kl-kw model?
Old   May 14, 2015, 06:55
ahmed ramadan belal
ahmed ramadan is on a distinguished road
Could you send me papers about the model i m going to work on changing some constants of it so i have to know all thing about it
ahmed ramadan is offline   Reply With Quote
Old   May 22, 2015, 05:04
Jim
CFDYourself is on a distinguished road
-sean
Hi, I'm new here, this is my first post.
I can confirm what delfel has said. both k-kl-w and transition SST models in fluent require a fine mesh. Fluent reccomend y+ = 1 for the first cell height, and a growth rate of 1.1 in the turbulence modelling lit
CFDYourself is offline   Reply With Quote
Old   June 17, 2016, 14:35
Default New version of the model
  #15
Alberto
malv83 is on a distinguished road
After 8 years, there is a new version (or new model) of the k-kl-omega model.
There are a few problems with the k-kl-omega model in the farfield. One of them is the growth of Laminar Kinetic energy when separation occurs. Lopez and Walters have a paper (have not been published yet) correcting this issue:
Maurin Lopez. D. K. Walters. “A recommended correction to the k-kl-omega transition sensitive eddy-viscosity model”. Journal of Fluid Engineering.
This correction has to be made to the 2008 k-kl-omega model from now on.
Now, Lopez and Walters also developed a new transitional model (k-omega-v2) as an alternative to the k-kl-omega one. This new model has more capabilities (it is more reliable) than the k-kl-omega model, especially in the farfield computations. Fortunately the paper for this new model is already publish.
Maurin Lopez. D. K. Walters. “Prediction of transitional and fully turbulent free shear flows using an alternative to the laminar kinetic energy approach”. Journal of Turbulence, Vol 17, Iss. 3, 2016.
If you see the papers, you will immediately see how the k-kl-omega model is not good for free shear flows, and how the new model corrects all those issues. From now on, k-kl-omega users have to start using the new k-omega-v2 model.
Hope this helps
Far, smrutimaya and Younis saleh like this.
malv83 is offline   Reply With Quote
Old   June 17, 2016, 14:41
Far
Sijal
which version?
Old   October 13, 2016, 12:14
Alberto
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model us FLUENT 5 April 5, 2011 02:29
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 16:42
validating turbulence model on flow around a car Pedro CFX 1 February 20, 2008 16:32
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
