Regarding change of tube material of shell and tube heat exchanger |
October 16, 2016, 22:39 |
Kiran KJ
Recently,I performed a CFD analysis on a shell and tube heat exchanger using Ansys fluent 16.2 .
k-e model with standard wall functions was selected.Also,energy was set to on. Inner fluid domain,Tube,shell were defined. The problem is that I tried to alter the inner tube material ,initially it was copper ,then I used Steel. During,2nd analysis no other parameters changed. But,there was no change in temperature drop of working fluid from inlet to outlet. How to deal with it? Is there any command to consider the thermal conductivity of tube material while calculating heat transfer. |
ansys fluent 16.2, heat transfer, shell and tube, tube material |
Shell and tube heat exchanger | nitish_a | Main CFD Forum | 1 | March 31, 2016 07:13 |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 04:28 |
shell and tube heat exchanger... | ganesh chakravarthi | CFX | 3 | July 6, 2015 18:44 |
Analysis of shell and tube heat exchanger in Ansys | Dena | FLUENT | 0 | June 12, 2015 13:39 |
shell and tube heat exchanger | samidabest | FLUENT | 0 | January 8, 2013 03:26 |
