Error appeared: "cx-restore-view: no views are stored"..Need help |
October 21, 2016, 06:32 |
Rep Power: 9 |
Hello everyone.
I'm trying to simulate a reactor whose reaction chamber is surrounded by porous walls and then by pressure bearing wall. between these two, there is water slightly pouring into reaction chamber. But the following are appearing. 1- Error: cx-restore-view: no views are stored Error Object: #f Setting Post Processing and Surfaces information ... Error: lvectorlength: wta(1) Error Object: () 2- How to improve its meshing to deal with the following error... WARNING: Mesh check failed. To get more detailed information about the mesh check failure increase the mesh check verbosity via the TUI command /mesh/check-verbosity. Fluent can also try to fix the mesh check problems via the TUI command /mesh/repair-improve/repair. Thanking in anticipation. |
Error appeared: "cx-restore-view: no views are stored"..Need help | Omer Bin Hussain | FLUENT | 2 | October 25, 2016 01:08 |
