When taking flow equation into consideration
Old   October 24, 2016, 12:42
Default When taking flow equation into consideration
WEN
wex415 is on a distinguished road
Hi all. I am working on a Phase Change Material melting progress, it occurs in a cylinder capsule (D=7.5mm H=15mm); the bottom and side walls of the capture are keeping heated by 310K.
The PCM I choose RT-27, melting temperature is 302K. I am simulating the close-contact melting, So I do not use the VOF model. When not taking flow equation into consideration, the total melting time is 450s, but when flow equation is applied, the totally melting time reduced significantly to 80s.
Can anybody tell me what is wrong with it?
wex415 is offline   Reply With Quote
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Isothermal fluid flow and the Energy Equation ksq Main CFD Forum 6 September 18, 2013 06:27
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
