October 29, 2016, 04:30 |
making a single velocity pulse in fluent
mike
Hi there,
I am fairly new to ansys fluent and I need to create a tabular transient profile for a two phase flow system with fuel vapor going into a cylinder from a very small inlet. The velocity profile of the fuel is not constant as it needs to create vortex rings so adjusting for time will be the easiest way to do it. however i don't understand all the aspects to the table form and my first try at making this table does not seem to show on user defined profiles for inlet after i read the profile. my transient table looks like this so far inlet 2 6 0 time velocity 0.1 0.0000008 0.2 0.0000800 0.3 0.0080000 0.4 0.8000000 0.5 0.0008000 0.6 0.0000008 (could someone also please explain what these 3 numbers next to the profile inlet is meant to represent, i know this may seem like a stupid question but have my own interpretations and i could easily be wrong) Would this table be sufficient for two phase flow (correct format excluding the brackets)or would i have to add something extra to specify which phase this will apply to. Also could someone please instruct me on how to read this on ansys from notepad, i tried using the text command to read transient table and ansys says its reading file but nothing happens, any advice? Any help will be appreciated. |
A Question About Setting Whole Velocity Field Using "Proflie" in FLUENT | adsl17754 | FLUENT | 5 | July 31, 2018 04:29 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
Velocity profile interpolation FLUENT | Mustafa1986 | FLUENT | 3 | April 28, 2015 03:23 |
In fluent post processing, difference between, x velocity and axial velocity? | padmanathan | FLUENT | 3 | December 20, 2014 15:13 |
