Turbulent shear stress
i simulated turbulent flow in a channel, i created a custom field functions and after 4 flow through time i averaged and plot turbulent stress u'u', v'v' and u'v,
-u'u' =(2 / density) * viscosity-turb * (dx-velocity-dx) - (2 / 3) * turb-kinetic-energy -v'v' = (2 / density) * viscosity-turb * (dy-velocity-dy) - (2 / 3) * turb-kinetic-energy -u'v' = (1 / density) * viscosity-turb * ((dx-velocity-dy) + (dy-velocity-dx)) i used kw-sst model but i am getting large error as compare to experiment result , please suggest me where is mistake. thank you |
What variable or parameter are you comparing with experiment
I am not satisfied with the velocity stress, since k-w k-epsilon, or SA or kw std or keps (standard) all are designed to model Reynolds stress, which otherwise are computed using RSM model. I think you will not get something right with intentionally computing u'v' yourself. and also if your are using custom field function , first you will need to compute kinetic energy as well.
how can i compute u'v', is there any other method to calculate u'v', u'u' and v'v'. please give me some detail |
Try to use RSM model, if your computational power allows, otherwise try to use the custom FF of Kinetic energy then compute u'v', but I do not think this will give you some answers with k-w or k-epsilon , just try to do it. But first try to use RSM
actually in fluent there is kinetic energy as a variable is available can i use that in place of custom FF for kinetic energy? and if not then can you please tell me how can i create kinetic energy custom field function. thank you |
I think you should be able to use TKE=0.5*(mean(ux'ux')+mean(uy'uy')+mean(uz'uz'))
