Home > Forums > FLUENT
Periodic flow monitoring in ANSYS fluent
Old   November 8, 2016, 12:23
Default Periodic flow monitoring in ANSYS fluent
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Dear Fellows,
I want to use periodic flow monitoring in Fluent. where you go to residuals menu and below that there is a menu for statistics. In that you monitor per/pr-grad. Which means periodic pressure gradient. Has anyone used it? I ran the iteration and its getting increasing towards some positive or probably zero value. The curve began from -9e6 which is decreasing to zero or positive (not sure) per iteration. the curve is schematically shown in Figure attached. Where should I stop? isnt the gradient very large?
Shamoon Jamshed is offline   Reply With Quote
Old   March 5, 2017, 09:37
Shamoon Jamshed
Any reply on that? Please comment!
Old   March 5, 2017, 22:41
Lucky Tran
LuckyTran will become famous soon enoughLuckyTran will become famous soon enough
Your solution isn't converged until that periodic pressure drop is converged.
It could be positive or negative depending on the order you selected the surfaces. You should have a feel for what this number should end up at, because it's the expected pressure drop for the mass-flow that you specified.
Old   March 6, 2017, 04:38
Shamoon Jamshed
Ok, but i have taken one pitch length (I mean I am modelling a helical geometry) so I took one groove and made the model sweep along z direction up to one pitch. So I do not know the exact pressure drop that should be obtained, I only know the mass flow rate. I have two translational and two rotational periodic boundaries.
Old   March 6, 2017, 04:45
Shamoon Jamshed
Please see the following link as well:
Translational Boundary Conditions along with Rotational Periodic Boundary Conditions
Regards,
Old   March 11, 2017, 06:44
Shamoon Jamshed
Please any comments on the above link and the above problem, its a bit urgent! I really need help!
Old   March 11, 2017, 06:46
Shamoon Jamshed
And how one can see the mass flow convergence when there is no inlet and no outlet specified, I mean that in reports--> Mass flow inlet, upon which surface one can see this?
Old   March 11, 2017, 07:32
Lucky Tran
You should be able to select the periodic surface and report the mass flow rate. It should be very close, but won't be exactly equal to the mass flow you specified.
Since you specified the mass flow rate, it's better to monitor the pressure drop as a convergence parameter. Checking the mas flow rate only tells you how well your boundary condition is being applied, it doesn't tell you if your solution is converged or not.
Old   March 11, 2017, 08:23
Shamoon Jamshed
Please see the link as well, the problem is not limited to mfr! the interpretation of results is also problematic. I am not getting correct temperature at near the exit plane, (near one of translational periodic interface) and I applied flux on the topwall.
Thread Tools
Trackbacks are On
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 8 October 25, 2016 19:48
Ansys fluid flow fluent missing dave121/ ANSYS 7 February 27, 2016 06:41
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 29 November 3, 2015 06:33
Modelling Slug Flow in ANSYS Fluent VOF. OliverMechEng2208 Fluent Multiphase 1 March 18, 2015 06:45
problem with periodic BC in ansys fluent josephmp FLUENT 0 February 8, 2015 09:32
