DPM-flow rate is not same in reports
Old   November 15, 2016, 03:17
Default DPM-flow rate is not same in reports
yun
gush is on a distinguished road
i am dealing with DPM for a while.
my study case is simple for now. inert particles 2 micro meter. there is an enclosure with one inlet and two outlets.
in injection section i set the flow are as 1,47*10^-11 kg/s
and in this case inlet concentration would be flow rate/velocity/area ? am i wrong?
and this value is (1,47e-11)(kg/s) / (0,111 m/s) / (0,0016 m2)=8,28e-08 kg/m3
but after the DPM iteration reports says the inlet concentration is 8,47e-08 kg/m3.
how can it be?? i solved some other similar cases and everytime there is a 2-3% difference between the set value and report!
gush is offline   Reply With Quote
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
Exit Corrected Mass Flow Rate Mesh Sensitivity Study s__s__s CFX 4 July 20, 2016 11:46
two fluid, volumetric/mass flow rate at different volume fractions Veronique Pe CFX 2 November 26, 2014 05:30
Run-time postprocessing - incorrect flow rate through faceZone billie OpenFOAM Post-Processing 54 December 2, 2013 05:55
Urgennt : DPM Mass Flow Rate chouki FLUENT 4 July 30, 2008 10:24
