UDF help
Old   November 16, 2016, 05:20
Default UDF help
Mike McManuc
BigMc is on a distinguished road
Hi, Im hoping someone of you could please help me with a UDF that has been wrecking my head for a while now, I want to model a 3 bladed vertical axis turbine in 2D, I was hoping the UDF would do that. I have come up with a functions that relates the pitching angle to the azimuth position, implemented using an If and else statement and set the azimuth to the initial position(theta0) + the time step(thetap1)
however after the 1st rotation I run into trouble here as I dont have a reset condition, could anyone help out here?
Im also having problems with getting it to work successfully, I thought having a pointer for *Angle would set my angle similar to others like omega, however it does not, Can anyone help? I'd be eternally grateful
any help or advice would be greatly appreciated,
Thanks
BigMc is offline   Reply With Quote
Old   November 22, 2016, 12:10
Mike McManuc
Could someone PLEASE provide some assistance in relation to this.
Thanks
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 02:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 09:01
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
