Home > Forums > FLUENT
'' Surface Monitor '' ''Interior_BC''
Old   November 21, 2016, 07:05
Default '' Surface Monitor '' ''Interior_BC''
Onur Özcan
oozcan is on a distinguished road
Hi all,
I am working on heat transfers over 3d mould equipments.
I wanted to monitor as area weighted averaged for any 3d part.
like , Surface monitor > Interior_3d part.
what region is defined as Interior_3d_part ?
I may monitor that 3d part to see differences in temperature in volume monitor. But I just wonder what it stands for?(surface monitor>interior in 3d part
oozcan is offline   Reply With Quote
Old   November 21, 2016, 08:59
Kushal Puri
Kushal Puri is on a distinguished road
For defining the surface monitor, just select the, Report type (area weighted average), then field variable (eg : temperature, if you want to monitor temperature) and the select the surface on which you wan to monitor.
Turn on plot
Kushal Puri is offline   Reply With Quote
Old   November 21, 2016, 09:27
Onur Özcan
actually I would like to ask difference between in volume monitor and interior_BC for surface monitor.
I have a solid part and contacts to fluid zone. I would like to see how temperature distribution of solid zone is (steady-state). That's why, I selected regarding cell zone in volume-monitor. But there is interior_BC in surface monitor give same results in temperature in same way. That's why I ask above question.
Old   November 21, 2016, 14:20
Lucky Tran
LuckyTran will become famous soon enoughLuckyTran will become famous soon enough
The interior surface is the collection of faces of the interior cells (think of it as all the non-boundary cell faces).
However, what you are saying does not make sense. If want to do blah blah blah on a 3D part, you should be doing a volume operation. If you want to do area-weighted average on blah blah blah, that implies you are working on a surface.
The zone is the region.
Old   November 23, 2016, 06:24
Onur Özcan
yeah cool, thank you for your valuable answer.
Ok, well, if it is collection faces of a cell, for example, think about a rectangular, what exactly does it represent? collection of longitudinal or transverse?
Old   November 23, 2016, 12:52
Kushal Puri
Rectangular what ?, Actually still i dont understand your question. What you want.
Area weighted average things you can find on 2d surface (eg wall, 2d interior etc) not on the 3d part. On 3d cells you can find the volume integral of mass average, mass, volume average of any property.
It will be good if you tell exactly what you are trying to find.
Old   November 23, 2016, 13:02
Onur Özcan
well, all proofs are attached.
as you can see writing ''neckring'' . It is a cell zone and actually 3d body. Well, FLUENT create interior BC with its name and then, I have selected it in surface monitor. That's why I ask that that what interior seen in surface monitor mean?
Thread Tools
Trackbacks are On
Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan Open Source Meshers: Gmsh, Netgen, CGNS, ... 3 October 22, 2015 11:05
[gmsh] Vertex numbering is dense KateEisenhower Open Source Meshers: Gmsh, Netgen, CGNS, ... 7 August 3, 2015 10:49
SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Mesh Utilities 1 February 25, 2015 08:05
boundaries with gmshToFoam‏ ouafa Open Source Meshers: Gmsh, Netgen, CGNS, ... 7 May 21, 2010 12:43
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
