November 30, 2016, 09:10 |
Fluent - High Skewness in solids
Vaclav Piskacek
Rep Power: 10 |
Hi, Iam simulating water flow (+-9m/s) in nuclear reactor.
Skewness everywhere in water domain is <0,98. I have 4 cells out of 4,5 milion with higher skewnes which I can't reduce it by any means. One of them is 0,995. Will this be a problem if that cell is in solid domain? Is skewnees just a matter of concern in fluid domains? |
November 30, 2016, 11:31 |
#2 | |
Onur Özcan
Rep Power: 12 |
Could you share with your meshing. Are cells having higher skewness in relatively considerable location? |
November 30, 2016, 11:46 |
#3 | |
Vaclav Piskacek
Rep Power: 10 |
November 30, 2016, 11:54 |
#4 | |
Onur Özcan
Rep Power: 12 |
November 30, 2016, 11:56 |
Onur Özcan
Rep Power: 12 |
and, I would like to see mesh you have done by sending me (onrzcan@hotmail.com)
December 1, 2016, 04:56 |
#6 | |
Kushal Puri
Rep Power: 12 |
Hope this may help |
December 1, 2016, 05:48 |
#7 | |
Vaclav Piskacek
Rep Power: 10 |
December 1, 2016, 06:12 |
Kushal Puri
Rep Power: 12 |
Its not always that your continuity residual should be too less.It depends upon the physics may be some reverse flow may be there. you can monitors some other parameters like mass imbalance and heat flux imbalance if that coming ok, then no need to worry about the continuity residual.
December 1, 2016, 06:32 |
#9 | |
Vaclav Piskacek
Rep Power: 10 |
Where i can find heatl flux imbalance? |
December 1, 2016, 06:42 |
#10 | |
Kushal Puri
Rep Power: 12 |
I am not able to see the report can you paste it directly |
December 1, 2016, 07:06 |
#11 | |
Vaclav Piskacek
Rep Power: 10 |
-------------------------------- -------------------- interior-hpsi_2-solid -573.10658 interior-hpsi_2-solid.1 -0 interior-hpsi_3-solid 731.32575 interior-hpsi_3-solid.1 -0 interior-hpsi_5-solid 546.10172 interior-hpsi_5-solid.1 -0 interior-sachta-solid 445571.25 interior-sachta-solid-spodek-objem 0.060006303 interior-sachta-solid.1 -0 interior-sani_2-solid 178759.53 interior-sani_2-solid.1 -0 interior-sani_3-solid 178984.5 interior-sani_3-solid.1 -0 interior-sani_5-solid 149351.71 interior-sani_5-solid.1 -0 interior-spodek-objem 180.2848 interior-vstup-solid -26266.429 interior-vstup-solid.1 -0 interior-vytlak_2-solid 102403.84 interior-vytlak_2-solid.1 -0 interior-vytlak_3-solid 104384.28 interior-vytlak_3-solid.1 -0 interior-vytlak_5-solid 107002.32 interior-vytlak_5-solid.1 -0 ---------------- -------------------- Net 0 Total Heat Transfer Rate (w) -------------------------------- -------------------- ---------------- -------------------- Net 0 Radiation Heat Transfer Rate (w) -------------------------------- -------------------- ---------------- -------------------- Net 0 |
December 1, 2016, 07:11 |
#12 |
Onur Özcan
Rep Power: 12 |
you could just look for inlet and outlet mass flow rate. (that means mass imbalance), that is valid for continuity equation.
December 1, 2016, 07:12 |
#13 | |
Kushal Puri
Rep Power: 12 |
December 1, 2016, 07:14 |
#14 | |
Vaclav Piskacek
Rep Power: 10 |
Mass Flow Rate (kg/s) -------------------------------- -------------------- inlet-1 1422.3698 inlet-4 1411.0393 inlet-6 1419.4875 inlet-hpsi2 -0 inlet-hpsi3 -0 inlet-hpsi5 -0 inlet-sani2 1412.9978 inlet-sani3 1411.938 inlet-sani5 1410.2048 outlet-dno -8488.2092 ---------------- -------------------- Net -0.17198306 Inlets at HPSI are at start of transient 0 kg/s, so this is ok... Is the net imbalance ok? What could be the reason of such inbalance? > Total Heat Transfer Rate (w) -------------------------------- -------------------- inlet-1 1.4806849e+09 inlet-4 1.4688201e+09 inlet-6 1.4776143e+09 inlet-hpsi2 -22109.282 inlet-hpsi3 -20397.35 inlet-hpsi5 -26342.82 inlet-sani2 1.4695309e+09 inlet-sani3 1.4697556e+09 inlet-sani5 1.4679514e+09 outlet-dno -8.8342267e+09 ---------------- -------------------- Net 61699.701 |
December 1, 2016, 07:22 |
#15 |
Onur Özcan
Rep Power: 12 |
as far as I am concerned, mass balance difference is very high (0.172 kg/s ), equals to 619,2 kg/hour
December 1, 2016, 07:23 |
#16 |
Vaclav Piskacek
Rep Power: 10 |
December 1, 2016, 07:25 |
#17 |
Onur Özcan
Rep Power: 12 |
if you are solving for heat transfer, second order upwind schemes give better convergences, which discrete schemes has you chosen? (momentum,energy and turbulence (if there is )
December 1, 2016, 07:27 |
#18 | |
Vaclav Piskacek
Rep Power: 10 |
December 1, 2016, 07:33 |
#19 |
Onur Özcan
Rep Power: 12 |
and materials? could you write in or show screenshots?
December 1, 2016, 07:34 |
#20 |
Vaclav Piskacek
Rep Power: 10 |
How to find cells whose skewness exceed 0.98 in Fluent? | swtbkim | FLUENT | 12 | March 5, 2017 09:31 |
[ANSYS Meshing] Problem with High Skewness Mesh | CFD2016 | ANSYS Meshing & Geometry | 12 | June 8, 2016 01:28 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
[GAMBIT] Problem with boundary layer - high skewness | Muffins | ANSYS Meshing & Geometry | 4 | February 28, 2014 07:34 |
[GAMBIT] tangent edges and high skewness | CaroVandame | ANSYS Meshing & Geometry | 8 | May 7, 2012 09:39 |
