How to Mix AIR and WATER
Old   March 24, 2012, 06:28
Default How to Mix AIR and WATER
Alvise
Elvis1991 is on a distinguished road
Hi all, I'm e beginner with FLUENT.. I need to konow how to set up Fluent to mix air and water in a pipe with 2 different intlet that converge into one outlet. What I have to do?
Thank in advance!
Elvis1991 is offline   Reply With Quote
Old   March 24, 2012, 10:27
Snail
evswbok is on a distinguished road
hiŁ¬
1. import your mesh in Fluent .
2. in the object tree ,double-click models>muliphae-off.
3. choose mixture and number of eulerian phase is set to 2 in the dialog box.
Okay,good luck !
evswbok is offline   Reply With Quote
Old   March 24, 2012, 12:43
Alvise
Thanks for your replay! But in boundary condition for intlet water and intlet air
Which option i must select to define if it s water or air?
Old   March 25, 2012, 04:24
Snail
define the same,but u should choose a different material.
Old   March 25, 2012, 10:46
Alvise
Ok! But if i set phase: air for air intlet and respectly for water and mixture for other parts of my geometry, whith k-e models for turbolence the programm diverges at 10-15 th step.. How it s wrong?
Thanks for your time!
Old   March 25, 2012, 10:53
Snail
sorry,i dont know what your mean , could u post some screenshots?
Old   March 25, 2012, 10:55
Snail
with more detail
Old   March 25, 2012, 11:21
Alvise
Ok I'm not at home.. so I hope this is enough:
but if you want more tell me
Old   March 26, 2012, 02:19
Snail
The image is compressed,which is so small .i can't see anything .
Old   March 26, 2012, 10:44
Alvise
Ok tell me all options you wanna see.
I set:
Models->MultiPhase: Mixture (2 Eulerian..)
Models-> Viscous Model: k-epsilon (2 equations)
For boundary condition all set to wall except for: water intlet (velocity intlet), air intlet (pressure intlet) and outlet (pressure outlet)
but if i set in the boundary condition pannel a different option in the phase menu ex: phase 1 (air) instead of mixture most option don't appear in the edit menu:
http://www.freeimagehosting.net/73gq5
Old   March 28, 2012, 12:40
Alvise
maybe this can be useful to help me:
My setting:
this is what pannel print:
writing rp variables ... Done.
writing domain variables ... Done.
writing solid (type fluid) (mixture) ... Done.
writing air_int (type velocity-inlet) (mixture) ... Done.
writing water_int (type velocity-inlet) (mixture) ... Done.
writing interior-solid (type interior) (mixture) ... Done.
writing outlet (type pressure-outlet) (mixture) ... Done.
writing tube_water (type wall) (mixture) ... Done.
writing tube_air (type wall) (mixture) ... Done.
writing mixing_tube (type wall) (mixture) ... Done.
writing tume_mix (type wall) (mixture) ... Done.
writing tume_mix (type wall) (water) ... Done.
writing mixing_tube (type wall) (water) ... Done.
writing tube_air (type wall) (water) ... Done.
writing tube_water (type wall) (water) ... Done.
writing outlet (type pressure-outlet) (water) ... Done.
writing interior-solid (type interior) (water) ... Done.
writing water_int (type velocity-inlet) (water) ... Done.
writing air_int (type velocity-inlet) (water) ... Done.
writing solid (type fluid) (water) ... Done.
writing tume_mix (type wall) (air) ... Done.
writing mixing_tube (type wall) (air) ... Done.
writing tube_air (type wall) (air) ... Done.
writing tube_water (type wall) (air) ... Done.
writing outlet (type pressure-outlet) (air) ... Done.
writing interior-solid (type interior) (air) ... Done.
writing water_int (type velocity-inlet) (air) ... Done.
writing air_int (type velocity-inlet) (air) ... Done.
writing solid (type fluid) (air) ... Done.
writing zones map name-id ... Done
iter continuity x-velocity y-velocity z-velocity nut vf-water time/iter
1 1.0000e+00 8.0679e-03 7.4581e-03 9.1414e-03 1.6030e-01 7.5561e-03 0:02:26 99
2 1.0000e+00 3.2011e-03 3.2540e-03 3.2137e-03 1.1005e-01 4.6166e-03 0:02:15 98
3 1.0000e+00 1.6270e-01 1.0897e-01 1.1031e-01 4.4047e-02 5.1906e-02 0:02:26 97
4 7.0261e-01 6.3532e-02 3.4774e-02 3.4205e-02 2.7371e-02 4.2526e-02 0:02:15 96
5 6.1547e-01 4.3818e-02 2.6968e-02 2.5426e-02 1.8258e-02 4.4974e-02 0:02:06 95
6 7.2239e-01 4.7185e-02 2.7330e-02 2.6915e-02 1.4750e-02 5.3023e-02 0:02:17 94
7 1.3012e+00 6.1805e-02 2.8103e-02 2.8259e-02 1.5582e-02 7.3358e-02 0:02:07 93
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 31 cells
8 8.2346e+01 1.0233e+00 2.6506e-01 2.1635e-01 4.4897e-02 3.6242e-01 0:01:59 92
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1334 cells
9 3.8345e+07 1.3439e+00 2.3447e-01 1.7753e-01 1.6061e+00 4.6655e-01 0:01:52 91
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 13544 cells
10 4.7525e+21 9.0219e-01 2.4496e-01 3.1374e-01 6.6087e-01 3.3101e-01 0:02:05 90
reversed flow in 60 faces on pressure-outlet 7.
Error: Divergence detected in AMG solver: nut
Error Object: #f
Interrupting...
Done.
Old   December 1, 2016, 12:22
AMRITANSH AISHWARYA
amritansh is on a distinguished road
i have some problem in fluent, i want to import air-water mixture in fluent for multiphase flow simulation can u suggest me how to do it ?
amritansh is offline   Reply With Quote
Old   December 1, 2016, 12:28
AMRITANSH AISHWARYA
hi ... i have problem regarding multiphase flow but i dnt have mixture of air-water how to import that particular bcz there is no data for air-water
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 09:36
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Separation phenomenon of water, droplet and air Raymond CFX 0 July 9, 2004 22:59
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 07:04
