pressure jump with 12v fan?
Old   May 25, 2021, 05:04
Default pressure jump with 12v fan?
Hakan Enes
mavizasyon is on a distinguished road
I have to make a steady fan simulation on fluent with pressure jump thing but I dont have geometry or spesific fan, all I have I can use 12 volt any fan on internet (simulation is needed for battery cooling) . I don't known cfd theory and fluent much so I follow videos (I am student and this simulation is necesarry in a short term) . There aren't not enough tutorial about fan simulations with pressure jump on youtube (There are videos with fan goemetry that is rotating). I saw a video that use pressure jump and extracted parametres from a fan curve. The issue was that video is endonese. I have found some fan datasheets and there are fan curves but I don't know how to exteract parametres from that curve images like video. Another video which was belong ansys itself that used a parameter which is constant for simplicity, could it be enough for cooling simulation . Can any expert say what should I do?
Edit: And also if it is enough to fan model which is non-academical what should be the fan constant parameter?
Last edited by mavizasyon; May 25, 2021 at 05:12. Reason: a question and I forget to say on fluent
mavizasyon is offline   Reply With Quote
Old   June 1, 2021, 02:55
Vestdam
Vestdam is on a distinguished road
Hi
Ansys Fluent has a boundary condition for fans, where you can define the pressure jump as a function of the velocity.
Refer to:
https://www.afs.enea.it/project/nept...ug/node254.htm
Hope this is what you are looking for..
Vestdam is offline   Reply With Quote
fan, fluent, pressure jump
Pressure jump and momentum source Tanya FLUENT 1 June 4, 2009 15:22
Negative Pressure in fan modelling Jenny CFX 3 September 30, 2007 08:47
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
