December 25, 2016, 17:05 |
Creating Monitor
Rep Power: 9 |
Hi
I want to create a monitor between the inlet and outlet of a pipe (mass flow rate) for ensuring of convergence. can any one help me? |
December 26, 2016, 05:43 |
Kushal Puri
Rep Power: 12 |
December 26, 2016, 15:15 |
Rep Power: 9 |
when we select inlet and outlet in the same time in ''surfaces'', the monitor will show the difference of mass flow rate between the inlet and outlet at the end of run?
December 27, 2016, 00:51 |
Kushal Puri
Rep Power: 12 |
No no it will not give the difference. It will give you the values of inlet and outlet. For having the difference you can write the scheme file to monitor
December 27, 2016, 05:28 |
Kevin
Rep Power: 9 |
To add to that, in general it indeed doesn't give the difference, but sums the quantities in question instead. However, since you have an inlet and outlet, and area vectors are defined outward on boundaries in general if I'm not mistaken, it could be that you get the difference, as the mass flow rate on the inlet will be negative and on the outlet positive. It could be the other way around, I don't have access to Fluent at the moment, but you could just simply try it.
December 27, 2016, 08:32 |
Rep Power: 9 |
December 27, 2016, 08:37 |
#7 | |
Rep Power: 9 |
December 27, 2016, 15:31 |
Kevin
Rep Power: 9 |
That's indeed what I meant. I think if you select inlet and outlet as face when creating the mass flow rate monitor, it will give you the difference. Just give it a try and you'll know.
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
LES in DES can't be actived! | shenying0710 | CFX | 17 | January 23, 2014 04:45 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
