Elementary Fluent- tutorial: Flow over cylinder |
January 13, 2017, 11:30 |
Plaschko
Rep Power: 10 |
Hello everybody. I am new with FLUENT.I would like to find an elementary tutorial (such as an understandable version of SimCafe Singleton and Bhaskaran). In the latter tutorial I had to consdider two concentric cylinders (D1,2 =1, 64 m) and use the commmand "Surface from sketches" which did not work. To define a Booleans subraction of the two cylinders I tried extrude-command with equal depth (20 m). I used the outer cylinder (D1=84 m with frozen) as target Body and the inner cylinder (D1=1 m) with add material as target Body. In this way the Boolean subtraction was active, but the "Face selection filters" did not work. This leaded that the rest of the tutorial commands failed.
I would appreciate any comments on this problem. Thanks a lot, Peter |
Flow through small cylinder recirculated inside larger cylinder. | Keesie | FLUENT | 1 | July 28, 2016 04:30 |
Flow over an elastic mounted cylinder in Ansys fluent | rahilvalani | FLUENT | 0 | May 11, 2016 19:29 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Fluent v15 multiphase flow b.c. failure Non-channel flow | mickjazz | Fluent Multiphase | 1 | September 22, 2014 06:41 |
Incompressible, Unsteady Cylinder Flow | startingcfd | Main CFD Forum | 1 | March 15, 2011 01:12 |
