Fluent Post Processing - Faded contour
Old   January 13, 2017, 15:26
Default Fluent Post Processing - Faded contour
diogof is on a distinguished road
Hi!
I am trying to export some contour pictures by using the "Save Picture" option but the picture always comes out faded (see attached), except for the colorbar. I have tried a few formats but no luck. Does anyone know whats going on?
Thanks
Diogo
diogof is offline   Reply With Quote
Old   January 20, 2017, 09:13
Default Post Processing Faded Colour
Richard Merrett
Merrett is on a distinguished road
Hi Diogo,
You can change the colour using the viewing toolbar from the ribbon.
Within this there is a drop down for the lighting option which is by default set to 'flat'.
If you change this to 'Phong' then you will get the results that you are expecting.
It is important to consider the printing process though as it may be beneficial to leave them with a washed out appearance as it is easier to interpret the results on a printed page.
Regards
Richard
Merrett is offline   Reply With Quote
Old   January 20, 2017, 13:14
Kushal Puri
Kushal Puri is on a distinguished road
Originally Posted by diogof View Post
Hi!
Thanks
Diogo
Go to graphis and animation -> scene
Select the contour name and go to display turn off the lighting and apply
Kushal Puri is offline   Reply With Quote
Old   December 2, 2021, 07:39
James_mCFD is on a distinguished road
I'm not sure if Ansys has changed since this thread was posted as I cannot follow Kushal Puri's instructions when exporting an animation file. There is no "scene" menu, and in the "Graphics" section of the ribbon there is only the options of "Lights...", "Colourmap...", "Annotate..." and "Compose..."
I have also set the lighting option to 'Phong" as Merret suggested, but when I export the animation it is still as though we're watching it through frosted glass.
Why is it that Ansys by default seems to ruin contour plots with the lighting feature? Surely this is a feature that should be turned on and not turned off?
James_mCFD is offline   Reply With Quote
Post processing in CFD Post or Fluent. Blobs OpenFOAM Post-Processing 2 June 26, 2016 08:23
FLUENT adjoint solution post processing? fangr FLUENT 0 April 13, 2015 12:15
fluent parallel processing problem pedram.sotudeh FLUENT 0 June 19, 2012 02:32
Parallel Processing Problems Fluent 13 lstebe FLUENT 3 February 15, 2012 10:54
post processing for KIVA dirga Main CFD Forum 5 April 23, 2009 11:58
