Fluent Tui Command for transient
Like Tree8Likes
  • 6 Post By billwangard
  • 1 Post By MachZero
  • 1 Post By blackmask
Old   April 18, 2013, 11:47
Default Fluent Tui Command for transient
MachZero is on a distinguished road
Hello All,
I have found the fluent tui guide somewhat difficult to use because it often tells you what a command does, but not the subsequent path to get there. I searched through this guide and have not found how to transition a simulation from steady state to transient. This is important for initializing when using the automated parameterization. Has anyone come across this?
Thanks in advance!
MachZero is offline   Reply With Quote
Old   April 19, 2013, 16:05
Default TUI code to set transient solver
Bill Wangard
billwangard is on a distinguished road
;; To turn on unsteady first order
/define models unsteady-1st-order? yes
;; To turn on unsteady 2nd order
/define models unsteady-2nd-order? yes
;; To turn on steady-state solver
/define models steady? yes
;; To iterate with steady state solver (10 iterations)
(iterate 10)
;; To iterate with unsteady solver (10 time steps, with 20 maximum iterations per time step)
(physical-time-steps 10 20)
Hope this helps,
Bill Wangard, Ph.D.
Engrana LLC
gfoam, gaza, DungPham and 3 others like this.
billwangard is offline   Reply With Quote
Old   April 20, 2013, 14:16
Default Thanks!
That is extremely helpful! Thank you very much. I am so very glad we have an active and helpful community
Светлана likes this.
Old   April 20, 2013, 15:07
François Grégoire
macfly is on a distinguished road
Where the hell does that come from? Ok, I found, scheme commands : http://www.polo.ufsc.br/~tiagom/docu...programing.pdf
For a reason that I ignore, the command 'dual-time-iterate' doesn't work when I open a transient case, load data and try to iterate further. Nothing happens. Is this a bug? Thanks.
macfly is offline   Reply With Quote
Old   April 20, 2013, 23:48
blackmask will become famous soon enough
Use
/solve/iterate 200
/solve/dual-time-iterate 200 20
instead. I have never been able to appreciate the merits of LISP.
Ekta J likes this.
blackmask is offline   Reply With Quote
Old   January 17, 2017, 13:57
Ekta J
Ekta J is on a distinguished road
Could you please tell how to write for setting pseudo transient case using TUI?
Ekta J is offline   Reply With Quote
ansys, fluent, text user interface, tui
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Error in reading Fluent 13 case file in fluent 12 apurv FLUENT 2 July 12, 2013 07:46
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
