January 18, 2017, 20:50 |
T
Hello everyone,
I would like to get a correlation matrix of the temperatures in an air conditioned room. More precisely, I would like to analyze how wall surface temperatures and temperatures in the "occupied zone" correlate. I have already set up a Fluent simulation of my room and found some hints in the internet that I could use DesignXplorer for such an analysis. Does anyone have experiences how to set a temperature profile as an output parameter? I only found the possibility to define an expression in CFD Post (f.i. the average temperature of a subvolume) and set it as a parameter. But since I would like to separate the room in numerous sub-zones, it is really laborious to set each expression manually. It would also be nice to vary the resolution of the profile easily. I also tried to set the expressions in a for loop via pearl script. But so far, I wasn't able to execute it. Is there another way to export the temperature profile? Or are there other possibilities to find a correlation matrix? I hope you can help me and thank you very much in advance! |
