concentration gradient
1 Attachment(s)
hello
i enter mass transfer equation by using uds and at inlet boundary condition i want concentration gradient that i enter it with a udf but when i see concentration gradient at inlet in graphics its not correct for example top of it must be red color but its green what should i do |
Your UDF is not doing what you expect. You have two possibilities:
1. Change your expectations. 2. Change your UDF. |
Can you give me the UDF that you used, then maybe I can explain why it is not doing what you expect.
#include "udf.h" DEFINE_PROFILE(inlet_concentration, face_thread, i) { face_t face; real r[ND_ND]; begin_f_loop(face,face_thread) { F_CENTROID(r, face, face_thread); F_PROFILE(face, face_thread, i) = 3.3*100000*r[1]+5; } end_f_loop(face,face_thread) } |
Is it just a simply interpolation and graphical bug? In your UDF you specify face values, but you selected node values in the graphics. Your UDF doesn't specify the values at the other boundaries, the other walls?
once i didnt select node values but the result was not ok second question: no |
And how do you apply this UDF? Exactly which property is set to this UDF in Fluent?
To speed things up: what do you want your gradient to be?
If you want it to be 3.3*100000, you are doing it the wrong way... |
