December 14, 2017, 10:00 |
Zone motion to control turbine pitching
Ethan Walker
Rep Power: 8 |
This is quite a specific issue and I was hoping someone here might have experience or know of something that I could try. I am using Ansys fluent 17.1 to model a variable pitch vertical axis turbine. Each blade has its own specific rotating domain within an overall turbine rotating domain. I control the pitch of each blade independently by controlling the rotational velocity of each blade domain through the use of a UDF. my issue is that in the turbine that I am modelling the blades all pitch outwards the whole way round (rotate in the opposite direction of the turbine), the greater the pitch the more I specify the blade domain rotational speed. so I specify the rotational velocity always increasingly negative in rads/s ( eg -0.08 to -6 rad/s) when I get to the end of the rotation (at 360 degrees azimuth) the rotational velocity/pitch is approximately -6 rad/s, but at the start of the next rotation the pitch is only -4 degrees (approx 0.08 rad/s) this sharp instantaneous drop in rotational velocity causes my model to go unstable (turbulence and velocity unrealistic) I cannot think of a method where I can reduce the rotational velocity without affecting the pitch angle of the blade. If anyone has any advise/tips that would be great. Thanks |
ansys, fluent, fluent - udf, turbine, udf cg motion |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 14:07 |
Error in solution using "Grid Interface" | agustinvo | FLUENT | 4 | January 20, 2015 12:03 |
Different zone motion and mesh motion preview | aamer | FLUENT | 5 | September 24, 2012 13:58 |
Porosity profile, dividing a zone, or getting zone location from zone | khoopes | FLUENT | 0 | June 2, 2012 19:39 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
