The analyzing swirl flow
Old   January 25, 2017, 23:59
Default The analyzing swirl flow
kazuki
kazuki is on a distinguished road
Hi, I'm simulating the intake stroke of a Diesel Engine in Fluent. When I got results for Swirl ratio-Crank angle curve, the peak of swirl ratio valve is matching with my experimental value but, the crank angle at which the peak occur is not matching. The peak of experimental swirl value is around CA 100~120 deg..I use RNG k-ε model.Should I use RSM model? If you propose that, please tell me detailed setting.
Thank you in advance!
kazuki is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
swirl flow shulnak FLUENT 2 June 19, 2014 01:51
Plasma analysis in swirl flow yaledad FLUENT 0 February 8, 2013 16:43
swirl flow rvndr FLUENT 10 May 30, 2012 02:53
swirl flow in FolwWork Simulation linsir0825 FloEFD, FloWorks & FloTHERM 1 June 7, 2011 05:02
