January 25, 2017, 23:59 |
The analyzing swirl flow
kazuki
Rep Power: 9 |
Hi, I'm simulating the intake stroke of a Diesel Engine in Fluent. When I got results for Swirl ratio-Crank angle curve, the peak of swirl ratio valve is matching with my experimental value but, the crank angle at which the peak occur is not matching. The peak of experimental swirl value is around CA 100~120 deg..I use RNG k-ε model.Should I use RSM model? If you propose that, please tell me detailed setting.
Thank you in advance! |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
swirl flow | shulnak | FLUENT | 2 | June 19, 2014 01:51 |
Plasma analysis in swirl flow | yaledad | FLUENT | 0 | February 8, 2013 16:43 |
swirl flow | rvndr | FLUENT | 10 | May 30, 2012 02:53 |
swirl flow in FolwWork Simulation | linsir0825 | FloEFD, FloWorks & FloTHERM | 1 | June 7, 2011 05:02 |
