mass diffusivity in FLUENT
Old   November 24, 2008, 08:44
Default mass diffusivity in FLUENT
fadhil majnis
Hello, I need to determine the mass diffusivity in FLUENT. Can I get the diffusivity value directly in FLUENT or I need to write down UDF in order to get the diffusivity value?
Thanks.
Old   November 24, 2008, 10:30
Default Re: mass diffusivity in FLUENT
shoushibo
mass diffusivity in fluent is determined in material panel. or you will get the value in display>countors> Lam Diff Coef of species-n (in the Species... category)
Old   November 24, 2008, 22:53
fadhil majnis
hye, thanks to Shoushibo. I cannot find the Lam Diff Coef of species-n in the display window. I need to define something or what? I need to enable any model in define model?
Old   November 25, 2008, 11:00
shoushibo
do you activate the species model? if no ,you need. do you want to simulate a species transport in the mixture? in the material panel , there is a item about mass diffusivity. you may check it. good luck.
Old   November 25, 2008, 20:32
fadhil majnis
thanks shoushibo. Actually Im simulate a species transport for mixture in the Eulerian model. Im already found the mass diffusivity item in the material panel. What I want now is the mass diffusivity after certain time step of simulation. How can I get the mass diffusivity value for that?
Old   November 26, 2008, 09:12
shoushibo
it should be in the display/countor/species/lam diff of species n
Old   November 28, 2008, 11:09
fadhil
hi Shoushibo, I still cannot find the lam diff of species n as what you said. Im using Fluent 6.3. In the species model, I enable the species transport also the options diffusion energy sorce and full multicomponent diffusion. Is that I missing something in define the species and transport model? Thanks.
Old   December 2, 2008, 08:57
shoushibo
you can try to disable the full multicomponent,and see the results. i solve the binary diffusion in the speices model.
Old   April 15, 2010, 06:15
nishith dulet
nishith is on a distinguished road
hi me too facing the same problem...... i am defining two phases. where i want to include mass diffusivity... but i am not getting how to find out this mass diffusivity panel.... every where it is written ...that it is in the materials panel..... but i could not found ..... please throw some light....
nishith is offline   Reply With Quote
Old   November 5, 2010, 09:33
anonymous
yc9316 is on a distinguished road
just as the way given by shoushibo, display/countor/species(not properties)/lam diff of species n is the way to display laminer mass diffusive, my fluent version is Ansys 12. Refer to mass diffusive in materials panel, it is in mixture(material type) only. good luck.
yc9316 is offline   Reply With Quote
Old   January 29, 2017, 01:59
Default diffusivity
  #11
Moulish Kommu
moulish is on a distinguished road
Hai Iam also facing the similar problem but I want to know the fluent computed value after 1000 iterations, not how to specifiy at inlet
moulish is offline   Reply With Quote
define mass diffusivity for each zone kim FLUENT 1 October 17, 2011 20:36
mass diffusivity C_DIFF_L(c,t,i,j) pour FLUENT 2 May 31, 2008 15:00
mass diffusivity pour FLUENT 1 May 29, 2008 07:15
mass diffusivity saghir FLUENT 2 July 17, 2006 07:01
mass diffusivity Amanda FLUENT 1 September 11, 2001 20:19
