Displaying reporting message in the console slows my simulation |
January 31, 2017, 04:55 |
Rep Power: 16 |
Hello everybody,
I noticed that setting reporting interval to 1 (i.e. displaying messages- about residuals and warnings about reveresed flow - in Fluent consolle for each iteration) slows a lot the simulation (in this case transient multiphase). Is like if Fluent waste time showing that messages. I disabled warnings by setting solve/set/flow-warnings? to no and reporting interval to 100 and the simulation time decreased by a factor 4 . I know that sounds strange but it's true Has anyone noticed this before? In my simulation that is transient Fluent still display a message every time step: "Updating solution at time level N..." and I'm guessing that message slows in turn the simulation...how can I disable that message too? Thank you for your answers |
January 31, 2017, 05:17 |
Kevin
Rep Power: 9 |
Can't you just change the value of "Reporting Interval" found on the "Run Calculation" panel?
January 31, 2017, 05:27 |
#3 | |
Rep Power: 16 |
By the way have you ever noticed that printing messages to the console slows so much the simulation? Don't you feel that is a strange behaviour? |
January 31, 2017, 05:56 |
Kevin
Rep Power: 9 |
I'm not sure you can have Fluent not calculate the residuals every time step but every N timesteps. I've never used that; only changed the Reporting Interval. You could always disable "Plot" and "Print to Console" in the monitors, but I don't think you'd want to do that. They do give valuable information.
As for the printing to screen and plotting slowing your simulation down, yes, I am aware of that. Hence the option of not having Fluent do it every iteration. Depending on how many monitors you have, and especially the type, it can be quite costly to calculate them. Especially integrals over large surfaces/volumes require quite a lot of calculations. Plus, if you're running in parallel, processing data requires overhead and communication, which always slows your simulation down. |
Bounds error message with no observable effect on simulation | Chander | CFX | 3 | March 20, 2012 16:13 |
Linux Fluent console message | natantyt | Main CFD Forum | 0 | November 9, 2011 14:48 |
Turbulent viscosity message with rotating blade simulation | siw | FLUENT | 0 | April 17, 2010 10:40 |
Error message in CFX-10 | CFDworker | CFX | 2 | October 12, 2007 07:23 |
how to avoid reverse flow message | Amit Mahulkar | FLUENT | 0 | April 20, 2006 00:45 |
