How to obtain the velocity in each point I want
Old   February 7, 2017, 16:59
Default How to obtain the velocity in each point I want
juan esteban Suarez
juansc1941 is on a distinguished road
Hello, I have a simulation already done in fluent, I have de .Dat file of the results of the simulation, however this file shows me the velocity only in the nodes. I really want to have the value of the velocity in every point, not only in the nodes, and export this file as an ASCII file. Do anyone know a way to do this in fluent, cfd-post or tecplot? Thank you
juansc1941 is offline   Reply With Quote
Old   February 8, 2017, 06:39
Kushal Puri
Kushal Puri is on a distinguished road
Do tou know the location of the cordinates.?
Kushal Puri is offline   Reply With Quote
Old   February 8, 2017, 07:24
juan esteban Suarez
I define the location of the coordinates, the idea is to obtain the Information in many points that I define, not only the one given in the nodes. This implies that it should be an automatic procedure because there are a lot of points.
Old   February 8, 2017, 07:25
Kushal Puri
you just create points at the locations and then u can easily use the CFD table viewer to get velocity at all those points.
Old   February 8, 2017, 08:11
juan esteban Suarez
Thank you that is what I need. However I have 2 questions, I already create the point, but I donīt know how to put the value of the velocity of that point in the table.
Do you know a way to generate this points in an automated way?, I mean I need to generate points in all the mesh, that is like 4 Millions of points, so I canīt do it by hand.
Old   February 8, 2017, 08:36
pakk will become famous soon enough
In Fluent: File->Export->Solution Data
Select ASCII, the things you want and the settings you want.
pakk is offline   Reply With Quote
Old   February 8, 2017, 08:43
juan esteban Suarez
The problem of doing that, is that it only exports the values in the nodes and I want it in other points that I define
Old   February 9, 2017, 06:16
If your strategy to solve your problem involves the step of defining 4 million points and extracting information on those 4 million points instead of using the known information on the nodes, you probably have a inefficient strategy.
You can do this. Basic steps: find out how to use the Text User Interface to define these points, and use a scheme script to do this for all points that you need.
But you can probably spend your time better by re-thinking the method that you are using.
Velocity of injection point a_cucen FLUENT 2 June 13, 2014 09:48
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 06:51
a reconstructPar issue immortality OpenFOAM Post-Processing 8 June 16, 2013 11:25
I want to the velocity vector for the first node point to the wall. Can I use wallDis catapult OpenFOAM Programming & Development 0 January 13, 2012 08:25
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
