February 13, 2017, 03:04 |
Effect of gradient scheme on Nusselt Number
Saurav Kumar
Rep Power: 9 |
i am simulating laminar flow with heat transfer in a duct and i am using structure type of mesh. i used solve/set/expert to get Temperature gradient and based on that i defined local Nusselt Number. the problem is when i changed the gradient schemes from Green-Gauss cell based to Green-Gauss node based then Averaged Nusselt number (Area Weighted Average ) changed by 15% but there is no change in local nusselt number, how is this possible? i am totally confused. am i doing something wrong? pease suggest me. Thank you, Kind Regards, Srv |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
write out nusselt number (gradient of T, respectively) for timesteps | sven | OpenFOAM Programming & Development | 38 | January 2, 2017 04:59 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
