February 15, 2017, 00:42 |
Problem with VOF
CFD START
This is my first thread in the forum. I am trying to solve a 2d axisymmetric swirl steady state problem using a multiphase flow VOF model, laminar flow. After marking the region where VOF is of a 1 value and identifying this in the boundary conditions at the flow inlet. After the solution is converged, I found in the graphic results that:
Contours>>Phases>>volume fraction>>Phase-2 Min: 1 , Max: 1 this makes all the interior value as a same color. And this is pretty not indicative. Could you please assist to identify the problem? Thanks! |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
a problem of incompressible two phases(water and gas) with VOF Method | zhangweisnoopy | Main CFD Forum | 9 | August 12, 2011 08:25 |
Two-phase VOF problem | scott copland | FLUENT | 3 | March 15, 2007 07:25 |
A Problem with setting the time step in VOF model | Le | FLUENT | 2 | July 20, 2006 22:00 |
problem with VOF. | Marc | FLUENT | 1 | June 5, 2002 08:17 |
