How to create a surface of specified length for postprocessing?
Hello everyone,
I am trying to consider the Heat transfer coefficient at some surfaces. How do I create a surface zone at the place where I want for examining results? If I try to create "new surface /plane" I have to put in 3 points to define the location in 3D, but this gives me the surface which is infinite in the length direction. Can someone tell me how I can only display a surface with specified x and y length? Best regards h0rst |
Create the infinite surface as before.
Then do an iso-clip on that surface. It will create a new surface. You can clip using the mesh coordinates. |
Thank you, it worked perfectly out!:)
