How to open mesh file in Gambit /pls help
Old   June 25, 2007, 08:13
Default How to open mesh file in Gambit /pls help
FRAJ
Can anyone tell me how can I view a mesh file (*.msh) into Gambit ? I have available mesh file from a tutorial I need to open it with Gambit to see how the author draw the mesh but I don not know how?
Thanks in advance FRAJ
Old   June 25, 2007, 10:11
Default Re: How to open mesh file in Gambit /pls help
Ahmed Adel
hi you can not open a (mesh file ) in Gambit , the extensions that Gambit can view is:
1-(filename.dbs) to view the figure in gambit and specify intail boundry condittions
2-(filename.jou) to view the journal of the gambit
while (filename.msh) can open by fluent and yoy can display the figure and change intial boundry condittions you make in gambit.
Old   June 26, 2007, 04:57
milano
I think, that U can import *.msh file into gambit by clicking on: file -> import -> mesh -> choose Fluent 5/6 -> Browse -> load Your file *.msh milano
Old   June 26, 2007, 05:16
FRAJ
Thanks milano to the answer I follow your idea but i have the following error when i try open the mesh file please te\see it: Error: Error encountred while reading the header information. Gambit is unable to import C:\documents & setings\pipe.mesh
what the reson please ?
FRAJ
Old   June 26, 2007, 06:21
milano
That's hard to say, I don't know the software U used for the *.mesh cration. I used Gambit to crate the mesh file and maybe that's reason that it worked in my case. Check the heading of the file, if there is not any bug. Sorry. Or if U can load the file in Fluent, save it again in fluent (use another name) and try to repeat the first idea (gambit -> file -> ....) Milano
Old   June 26, 2007, 11:21
FRAJ
dear milano fluent save it as *.cas file only and this cannot be opened in Gambit as you know can you tell me how can i save it as *.msh in Fluent? This mesh file actually I downloaded it from fluent site for a tutorial 3 dimnesional so even me not know which software be used to draw it?
THanks a lot FRAJ
Old   June 27, 2007, 03:22
Dr. Flow Squad
Don't use space and "&" in directory names. -Dr. Flow Squad http://tinyurl.com/2gkjh8
Old   June 27, 2007, 04:13
FRAJ
dear Dr. flow squad actually I am not write the directory names when i open the mesh file I use browse then choose the directory.
FRAJ
Old   June 27, 2007, 04:20
Dr. Flow Squad
I meant move the files to a directory without spacing and open it from there. Like C:\CFD\mymesh.msh.
Maybe it will work. Maybe not. -Dr. Flow Squad http://tinyurl.com/2gkjh8
Old   June 27, 2007, 07:38
FRAJ
Thank you so much Dr. Squad it was opened at last. Now can you tell me how can I create a journal file to this *.msh file in order I saw how it be drawn because I was got it from a tutorial in the web? is there ability to do this?
Thanks so much FRAJ
Old   June 28, 2007, 04:31
  #11
sami
Hi Fraj! Just ask Mr. Mhiri See you soon
Old   June 28, 2007, 04:42
  #12
FRAJ
Who was Mr. Mhiri ?
FRAJ
Old   June 28, 2007, 04:48
  #13
sami
oh i am really sorry fraj, i am confused because i thought you was a friend of me dealing with the same purposes as you. so i advised to look for that with a professor in his institute i am reaaly sorry once again, i thought you was him good luck fraj
Old   March 2, 2011, 08:15
Basy's Avatar
behzad
Basy is on a distinguished road
thank you so much Dr. Flow, you helped me a lot. thanks thanks thanks
Basy is offline   Reply With Quote
Old   February 19, 2017, 01:36
Default how to convert .msh file to .dbs file
  #15
invincible
osamaajaz is on a distinguished road
kindly guide me how to convert .msh (mesh file) to .dbs (file that can be read by mesh)
i want to revise some structural parameters in same mesh
osamaajaz is offline   Reply With Quote
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 02:26
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
