February 19, 2017, 14:59 |
Ansys fluent help needed
Jad nakhl
Rep Power: 9 |
[Hello sorry disturbing but i posted earlier and no one answered.
If anyone can tell me how should i draw an expanding circular pipe without getting an error in the setup if want to make a line in the drawing as centerline and by putting the problem type as axisymmetric. |
February 19, 2017, 23:38 |
Lucky
Rep Power: 65 |
This is a meshing problem, not really a Fluent problem.
You need to generate a 2D mesh that represents your problem. Then you simply specify the centerline as the axis-type boundary condition in Fluent. My question is, what's your favorite meshing program? The very first ICEM tutorial will show you how to make a 2D box, you can fairly easily make that into an expanding pipe I think. |
February 20, 2017, 04:14 |
Jad nakhl
Rep Power: 9 |
Hello, first thank you for answering..
But if you can explain a little bit for how i should transform a box to an expanding pipe. Because i know that i can transform a box to a regular circular by putting the lower or the upper boundary as axis w and the type as axisymmetric. But the problem is how to draw a box with an inlet and a step right under the inlet. |
February 20, 2017, 08:01 |
Lucky
Rep Power: 65 |
Don't transform it. Simply draw it.
February 20, 2017, 08:09 |
Jad nakhl
Rep Power: 9 |
How should i draw it in the geometry in ansys fluent that's my point.. How should i draw a rectangle by dividing it's left side into an inlet and a step below and putting the upper vertical side as a centerline and type axis and the type of problem axisymmetric without getting an error.
Display Modes | |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Ansys structural and fluent for FSI | assafwei | FLUENT | 1 | June 20, 2014 10:56 |
Help Needed for very simple problem {ANSYS Fluent} | naikaj | FLUENT | 2 | March 13, 2014 00:35 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Fluent & Ansys FSI architecture help | DillonS | FLUENT | 1 | April 7, 2010 16:00 |
