Home > Forums > FLUENT
k-equation
Old   March 6, 2017, 13:43
Default k-equation
Diger is on a distinguished road
Here:
http://www.afs.enea.it/project/neptu...3.htm#eq-rsm-k
it says that for the boundary conditions of the reynold stresses the k-equation is solved globally and only the values at the boundaries are taken as input to the boundary conditions for the reynold-stresses.
I'm wondering: Do I not need boundary conditions for this k-equation at the wall again or are these velocity-fluctuations/turbulence = zero since they vanish for the same reason as the "real" velocity (no slip)?
Phyiscally is it because within the vicious sublayer any arising turbulence is immediately damped, because of the "strong" vicous role in it??
Diger is offline   Reply With Quote
Old   March 7, 2017, 03:09
Lucky Tran
LuckyTran will become famous soon enoughLuckyTran will become famous soon enough
You still need boundary conditions for the k equation. That is why there are near-wall treatment options when you use RSM.
In equilibrium boundary layers yes. However, "any turbulence arising" implies that there can be turbulence (or at least production of k). Immediately damped means that dissipation is equal to the production rate. Hence, equilibrium boundary layers are ones where the production rate is equal to the dissipation rate. However, these two combined allows k to be finite near walls.
Old   March 7, 2017, 06:23
And what are the precise boundary conditions for k then?
Do you have a link explaining it?
Old   March 7, 2017, 15:07
Lucky Tran
The boundary condition for k at walls should be the zero-gradient type.
Old   March 8, 2017, 06:04
pure neumann?
why? Whats the reason for this?
Old   March 9, 2017, 02:17
Lucky Tran
See section 4.16.2.4 in the Fluent Theory Guide.
The zero-gradient condition is simply, turbulence doesn't magically appear or disappear. It's like the adiabatic boundary condition for the energy (no spontaneous heat in or out).
If you set k=0 or any number at the wall, that means the wall is a massive turbulent kinetic energy reservoir/sink.
Old   March 9, 2017, 06:08
Ah yeah, I see...Like a diffusing species in a box which doesn't react with the walls and therefore doesn't get lost. (which is actually the same as the temperature thing)
Thread Tools
Trackbacks are On
Some problem of "Qcriterion.mcr& yuyuxuan Tecplot 9 February 12, 2016 04:27
rotational and inviscid Mike Main CFD Forum 7 April 20, 2011 02:25
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
Need help:about energy equation in CFX Stein CFX 4 July 2, 2009 22:31
Boundary conditions in a Poisson's equation? vincent Main CFD Forum 4 April 16, 1999 02:19
