March 7, 2017, 05:21 |
Monitors in Fluent
Rep Power: 10 |
Hi all,
As a fluent user, I use quite a lot the monitors but I find that I waste a lot of time doing the post processing of those. Is it possible to save monitors under the same file name? So that you can just copy all the values of all the monitors into an excel spreadsheet already built to post process them. Because it seems each monitor is exported into a specific file name so you have to copy each of the monitor one by one... seems a waste of time to me. Thanks for your help! |
March 8, 2017, 00:29 |
Jemyung Cha
Rep Power: 16 |
If you want to merge several monitor files into single excel spread sheet, you can use some script such as excel VBA or Matlab.
March 8, 2017, 03:20 |
Rep Power: 10 |
Thanks for your reply.
So I assume it is not possible to do it in Fluent directly? |
March 8, 2017, 04:14 |
Jemyung Cha
Rep Power: 16 |
As far as I know it is not possible to do it directly in Fluent.
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
