March 8, 2017, 10:27 |
Difference in near wall treatment
Rep Power: 9 |
Hi cfd members,
I wanna know the basic difference in standard wall functions, enhanced wall functions and scaleable wall functions. Tnx in advance! |
March 9, 2017, 01:39 |
Lucky
Rep Power: 65 |
Seriously this topic has been discussed to death already on this forum. Here's my short, spur of the moment response. If you google it enough you might find some contradictions, but I hope it gets you started.
First you need to understand what any wall function does and then what the standard wall function does. It's part of getting boundary conditions when your cell centers are very far from the boundary, and you can't solve for all the physics in between. So you start to assume that the flow does certain things as you approach the wall. And you use this assumed behavior to get your boundary conditions. The scalable wall function is like the standard wall function, except that it applies a limiter to the calculation of y+ (actually y*) that prevents the wall function from going into the low-y+ regime. The scalable wall functions allows you to use the log behavior anyway in the low-y+ region where you normally wouldn't apply them. There are pros and cons of this. The pros are that your solution doesn't blow up as you make the mesh arbitrarily small and keep trying to use wall functions. The cons is that you are still using wall functions in an area where you would rather brute force the turbulence model (like in the k-omega model). The enhanced wall treatment is the monster. The difference is that next to walls, instead of solving the full k-epsilon equations, you would rather solve the one equation model by Wolfshtein. So Fluent does both and then blends the two together. The blending isn't really important because it's just to make the model user friendly and make the numerics happy. The reason you want to solve Wolfshtein's model is because the epsilon equation doesn't work near walls (because the epsilon equation doesn't have two length scales). |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
wall roughness in enhanced wall treatment | lobstar | FLUENT | 7 | June 29, 2012 04:43 |
RSM with enhanced wall treatment | zwdi | FLUENT | 1 | April 24, 2005 20:36 |
