Pressure drop at various pipe locations
Hello all,
I have to perform a 3-D CFD analysis of air flow in a pipe using Fluent. Experimentally the inlet is attached to blower for providing some fixed mass flow rate or velocity. The length of pipe will be say 50 inches and i have to measure pressure at 5 diff. locations say- 5, 10, 20,30,40, and outlet at 50 inches. Q 1. What will be best model for analysis ? Q 2. Which type of boundary conditions should be applied at inlet and outlet - Velocity inlet and pressure outlet ? Q 3. How can i measure pressure difference at those 5 locations. Q 4. Will "Pressure-outlet" boundary condition by default sets Outlet pressure to Atmospheric pressure ?? Q 5. Will there be difference in these 2 Cases - Case A - Modelling full 50 inches and calculating pressure difference at 5 locations from one Simulation. Case-B - Modelling 5 lengths differently and analyze them separately with Pressure-Outlet boundary condition. I would like if the answer mentions to my question number. Thanx in advance :) |
1. What physics are you trying to model? Choose the model that contains those physics.
2. Never ask someone else what your boundary conditions are. You are always responsible for knowing this. If you don't, then go meditate until you do. Just like in mathematics, your problem is not specified until you have a a domain, governing equations, boundary conditions, and initial conditions. 3. Define a precise definition of pressure difference. Do you mean difference in pressure between two points, difference in average pressure between two planes? What are the planes, what are the averages? And then do so in Fluent. In Fluent it's very easy to export pressure at probe points and surfaces. And then you can calculate pressure drop on your own after. 4. The default value pressure outlet is 0 Pa. The default operating pressure is 101325 Pa. It is so easy to change these numbers though, does it really matter what the default settings are? 5. Yes there will be a difference, but arguably a small one. First, your mesh will not be the same, so you will end up with different results. Second, if you have the same velocity inlet and same atmospheric pressure at the outlet, you'll end up with different massflows. Third, even if you changed the outlet pressure for each case, at a pressure outlet boundary you are imposing a certain distribution (default uniform) for the pressure which may not match the distribution the flow would normally have. Therefore, in general, I recommend you do Case A. You can do Case B if you can't afford the computation. However, these days RAM and cpuhours are really cheap. |
Thanx for the Reply LuckyTran.. Well Actually i am confused mainly between pressure measuring system in Fluent. Like if a want to measure pressure drop at constant mass flow rate across 50 inch long pipe, should i model 50 inch exactly with the pressure-outlet condition or some extra length (10-15 inches) to eliminate the effect of immediate exit to the atmosphere and then measure at 50inch. In real experimental analysis, like pressure is measured few pipe diameters before the outlet to atmosphere. |
Hope you have some idea, how to proceed from here. |
Yes things are getting more clear now.. " Because even your pipe is discharging into the atmosphere the pressure at the exit is not the atmospheric pressure (it will be more then that)." - This makes things even more clear .. And yes the pressure conditions at outlet are unknown so it will be not suitable to use any specific pressure value at Outlet boundary condition.. Anyways i guess Pressure outlet condition with 3-5 pipe diameters extra than the require length will do the job. Thanks again for so much help. :) :) |
