March 14, 2017, 08:46 |
Using case check in fluent for Ansys 15.0
raunak jung pandey
Rep Power: 9 |
hello everyone
I read the fluent manual. I found previous fluent versions have check case in solve option to check the grid , the boundary condition and the solver settings. solve/Case check This option helps to troubleshoot most of the problems in settings. I tried to find same in Ansys 15.0 but says " this page is not applicable under current setting " . Is there any command used to implement such in Ansys 15.0 Thank You Last edited by raunakjung; March 15, 2017 at 02:00. |
March 14, 2017, 10:56 |
Rep Power: 13 |
i use Ansys 17. There is a button of CheckCase on the the top of the panel of Run Calcuation.
case check ; fluent |
Display Modes | |
[Commercial meshers] Problems converting a Fluent case file | McFly | OpenFOAM Meshing & Mesh Conversion | 12 | July 21, 2019 22:02 |
CFX overwhelming Fluent in mass convergence of boundary layer separation case | Pierre1 | FLUENT | 7 | March 26, 2015 22:43 |
Can't run a case in HelyxOS with an imported mesh from Fluent | HHOS | OpenFOAM Running, Solving & CFD | 0 | July 2, 2013 07:25 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
