a big problem when using VOF + melting/solidification model
2 Attachment(s)
hi, friends, i try to simulate the welding process using VOF + melting/solidification models in FLUENT. it is a simple principle that metal is solid and won't move below solidus temperature.
However, i found the situation was not like that. let's look a simple test case. this is initial state; constant ambient temperature; the whole region is considered as fluid domain. of course the melting/solidification model is used. Attachment 54618 after 0.02s Attachment 54619 metal material is apparently moving, which is wrong. any one have a idea about what is going on here? is it because the solid is a fake solid in VOF model? |
Okay the pics aren't labeled or anything but I'm guessing that blue/red is solid/liquid phases or vice-versa. The phase boundary should move in a melting/solidification problem. How are you sure the stationary solid has been moved versus motion of the phase boundary?
yes, the red is metal at solid temperature, the blue is air
comparing the tow figures, the interface shape apparently changed. |
i think i've figure out the reason. it is due to surface tension. I forgot set zero value of surface tension when temperature drop to below solidus point.
I'm running a test case to prove this hypothesis. |
Hi Pancard
I have same problem as you, did you find the solution? If you have foun that, help me please |
Hi Hossein/Pancard
Facing the same issue.. my solid metal is deforming even before the it reached solidus temperature. Please help. I have tried by taking surface tension as zero below solidus and 1.0 above liquidus temperature still the problem is not solved. |
