Fluent Script Setup For HPC- Writing Surface Monitors
I am trying to prepare a command script to run a case file on a linux high performance computer. After I ran the script and the solution was complete, I was only given a data and case file. I wanted to know if there is a line I need to use to have the surface monitors saved. Also how would I be able to view the data for these surface monitors. Thanks for your help |
I solved the problem. The code was incomplete.
