March 23, 2017, 22:54 |
How did YOU solve your skewness problem?
Richard
Rep Power: 9 |
Been getting the "skewness exceeds 0.98" error for my Fluent meshing pretty much regardless of what I do. Just curious to see what major steps I should be taking to troubleshoot this problem.
March 27, 2017, 01:57 |
SinaJ
Rep Power: 16 |
If you're using ANSYS Meshing module, there are two solutions I would look into:
1- Try to increase the "Min size" of the mesh, which will lead to less-accurate mesh (in terms of matching with geometry), but it will decrease the skewness in edges and ... 2- Try to decrease the "Max face size" and "Max Size". It will increase the overall number of the cells! So, less skewness on edges1 |
March 27, 2017, 08:32 |
Lucky
Rep Power: 65 |
Coarser grids do great things for reducing skewness.
Uniform grids are also helpful (make smallest cells bigger, and biggest cells smaller). If you're using an automated mesher you don't have control over the mesh topology. But if you're using ICEM for example, you can change the block structure. |
[ANSYS Meshing] High skewness problem | miquiita | ANSYS Meshing & Geometry | 25 | April 15, 2015 05:59 |
[Other] skewness problem in checking mesh! | gnut1989 | OpenFOAM Meshing & Mesh Conversion | 0 | February 3, 2015 05:49 |
Which multiphase flow to solve this problem? | mariam.sara | Fluent Multiphase | 3 | May 4, 2014 11:04 |
how to solve a problem involving both laminar and turbulent flow | seefd | FLUENT | 1 | June 3, 2011 03:20 |
Could CFX solve hydraulic jump problem? | Andy Chen | CFX | 0 | August 18, 2009 10:13 |
