Analysing multiple geometries with same boundary conditions. |
March 24, 2017, 03:41 |
Mathew George
Rep Power: 10 |
I need to analyse the flow through a pipe with a convex section. My study includes varying the angle the convex section makes with the pipe and finding the pressure loss each time. Is there any way in fluent to give the angle as a parameter that can be varied so that I don't have to redraw and remesh the geometries each time.
March 24, 2017, 10:03 |
valerie
Rep Power: 10 |
You can do it with parameters in DesignModeler or SpaceClaim.
If you do not use ANSYS cad tools, you can also create the different mesh and read the setting file. In this way, the setup is already configured. |
convex section, fluent, geometry ansys |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
PEMFC module + multiple periodic boundary conditions | vkrastev | FLUENT | 2 | December 22, 2014 04:15 |
