Species Transport problem
Old   April 6, 2017, 10:52
Default Species Transport problem
sunil kumar
skumar112 is on a distinguished road
Hello I am trying to simulate combustion of a jet (hydrogen + O2) PREMIXED USING THE SPECIES TRANSPORT MODEL. I am however getting issues with this and have got divergence. I have attached a screenshot of the screen as it blows up any help would be appreciated. If you require any additional information I will be pleased to include
skumar112 is offline   Reply With Quote
Old   April 6, 2017, 12:02
Lucky
Something's clearly wrong with the setup. Honestly, it could be anything.
I would start with running the mesh quality check and then check your initial conditions and boundary conditions.
Old   April 6, 2017, 15:24
sunil kumar
im sure the mesh is ok as i made it myself in icem, (and ive run the check mesh and fluent likes the mesh).
I think it might be to do with the boundary conditions as ive never used the species transport model before and might have done something wrong. i have a jet that sprays into ambient air, in the jet inlet I have a mass fraction H2 0.66 O2 0.33, for the ambient walls(pressure outlets) and inlet(mass flow inlet) I have mass fraction of O2 0.23, and at the inlet i have mass fractions for all O2,H2,H2O as 0 i assumed this as theres no backflow at the outlet its a pressure outlet.
Old   April 6, 2017, 15:29
Lucky
Make sure all your mass fractions add up to 1.
You can't specify all the mass fractions to 0 at the outlet. There should have been an error message to prevent this. You can't guarantee there will never be backflow. A pressure outlet is not a "there cannot be outflow" constraint. You expect there to be no outflow, but that doesn't mean there cannot be. Is there a reversed flow warning during simulation? There's only 3 iterations, it should not be hard to find.
What about your initial conditions?
Old   April 6, 2017, 15:44
sunil kumar
there was no reversed flow warning, I assumed it was ok as i found it on a tutoiral which does a very similar simulation to the one im running
https://www.google.co.uk/url?sa=t&rc...Oj-ov3ma4HSEzw
Old   April 6, 2017, 16:21
Lucky
First a question and then let me clarify.
You mentioned air, is N2 or something part of your mixture?
Your mass fractions must sum up to 1 no matter what or you will get a floating point error. You can set H2, O2, and H2O to 0 but that means there must be something else with a mass fraction of 1.
Next, if all the BC's are okay. Then check the initial condition.
Old   April 7, 2017, 05:53
sunil kumar
I think i have managed to fix the problem and it was the outlet boundary condition ... thankyou for your help
Species transport without reaction prince_pahariaa FLUENT 8 June 27, 2020 06:34
user defined scalar vs species transport gvj_mech FLUENT 0 March 27, 2014 15:33
problem about VOF and species couple Cloud FLUENT 0 June 15, 2012 02:23
Implement species transport equation Tobi OpenFOAM Programming & Development 0 June 2, 2012 14:26
Species Transport with multiphase flow Gopal Kasat FLUENT 3 July 12, 2005 19:59
