April 13, 2017, 05:13 |
convergence problem
Danial
Rep Power: 9 |
Dear friends,
I am just modeling a 2D water channel flow, using k-epsilon and one phase model and steady mode. as I set the the inlet with a low velocity (like 0.1 m/s) it doesn't converge. but as I set it high velocity( like 5 m/s) it converge easily. what is the problem? what should I do? |
April 13, 2017, 13:25 |
Lucky
Rep Power: 65 |
Try a different initial guess. I'm assuming the channel flow is already turbulent at 0.1 m/s, but is it possible that 0.1 m/s should be laminar?
April 14, 2017, 09:54 |
Danial
Rep Power: 9 |
Convergence problem in Fluent for quenching process | kaeran | FLUENT | 4 | December 1, 2014 02:14 |
Rotate frame reference convergence problem! | wjy-c | CFX | 2 | September 26, 2014 06:03 |
Centrifugal pump OpenFOAM, convergence problem, ANSA model | RDD | OpenFOAM Running, Solving & CFD | 0 | July 5, 2014 09:12 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
