April 22, 2003, 07:04 |
DPM and LES
We are working CFD modelling of hydrocyclones and are using LES for turbulence modelling. For simulating the particle trajectories we use DPM. When we use DPM with other turbulence models, in the "Display' "Particle Tracks" screen when we click "report type" as "summary" and the "report to" option as "file" then the "write" option automatically is displayed. This basically gives us the provision to write the results in a file and save it so that we can view it later. But this is not so in the case of LES with DPM . Even after the "report to file" option is clicked, the write option is not displayed. hence we are not able to write the results on to a file. also in the stochastic tracking model of DPM the number of tries option doesn't get on. Anyone of you have come across such problems. Please help R.sripriya
April 24, 2003, 01:56 |
Re: DPM and LES
Hi
the manual say DPM and LES are not compatible, I cannot tell you exactly the section number I guess 28. However, you can search at fluent userwebside fro compatibility and models Sorry to give you bad news! I try to use the LES and DPM long time ago, Even I get in contact to Fluent support and they give the same answer "I can not run DPM with LES" Regards Alex Munoz |
April 24, 2003, 02:17 |
Re: DPM and LES
Hi
Just I found the information on Fluent Appendix A Fluent Model compatibility A1 Fluent Model compatibility chart See by yourself Regards Alex Munoz |
May 13, 2003, 22:48 |
Re: DPM and LES
Hi, Thanks a lot for the information R.Sripriya
March 6, 2017, 20:42 |
dpm and les
Wu Jiandong
now dpm is compatible with LES
March 7, 2017, 14:25 |
Francesco Matacchiera
Rep Power: 9 |
April 15, 2017, 04:41 |
ddpm for big particuls
merrouchi farida
Hello
I work on the numerical simulation of multiphasic flows in a settling basin The flow is a mixture of water and solid particles of diameter 0.015 and 0.01 mm I want to know with which model I can particle for these particles |
DPM particle tracking in stirred tank | parisa- | FLUENT | 1 | August 7, 2012 12:03 |
Two way coupling in LES | ajkratos | FLUENT | 0 | March 14, 2011 04:14 |
Questions on DPM model..please | panos_metal | FLUENT | 3 | October 7, 2010 06:26 |
LES vs DPM | luigi | FLUENT | 0 | April 5, 2006 05:16 |
compatibity LES with DPM | Alex Munoz | FLUENT | 0 | March 26, 2003 21:13 |
