Udf dpm path
Old   April 20, 2017, 23:48
Default Udf dpm path
Yoon
touyet is on a distinguished road
Originally Posted by pakk View Post
Fluent UDF manual 2.5.1:
"For the return status PATH_ACTIVE, the particle continues to track. For the return status PATH_ABORT, the particle will be stopped and considered to be aborted. For the return status PATH_END, the particle will be stopped as well, but considered to have escaped from the domain."
If you want a particle to be "trapped", use PATH_ABORT; if you want a particle to be "escaped", use PATH_END.
Honestly, I don't know if there is any aspect in which Fluent treats "trapped" particles differently from "escaped" particles, but if I used this I try to choose the most logical condition in my situation.
As of Fluent 15.0, there are seven different statuses (see dpm_types.h, somewhere in your Fluent folder):
PATH_END
PATH_ACTIVE
PATH_BREAK
PATH_ABORT
PATH_STOP
PATH_NON_LOCAL_PERIODIC
PATH_NON_LOCAL
They are listed without explanation, and I don't know more. I would guess that PATH_BREAK indicated a break-up of a particle, and that PATH_NON_LOCAL_PERIODIC and PATH_NON_LOCAL might have to do with parallel issues. I don't know when PATH_STOP should be used, nor what it does.
Hi
currently I describe filter in fluent and I want know how to write UDF about Filteration.
I use
DEFINE_DPM_BC(bc_wall_jet, p, thread, f, f_normal, dim) to Porous Jump BC
and I want konw what is the PASS Though ( like interior ) Condition in below or ETC..
PATH_END
PATH_ACTIVE
PATH_BREAK
PATH_ABORT
PATH_STOP
PATH_NON_LOCAL
Need your help
Sincerely-
touyet is offline   Reply With Quote
Old   September 18, 2017, 13:41
Pengze Yang
Pengze Yang is on a distinguished road
Same question. Please help if someone has solved it!
Pengze Yang is offline   Reply With Quote
How to follow the path of a particle in DPM? upeksa Fluent UDF and Scheme Programming 2 November 26, 2014 12:18
please help me. i have question about the UDF at the DPM motallebi FLUENT 0 July 6, 2009 12:27
Velocity of Fluid @ different positions of Particle in DPM using UDF pmghadge FLUENT 1 June 16, 2009 20:11
DPM: using UDF for creating and deleting Particles Markus Alzon FLUENT 0 July 4, 2007 02:18
UDF DPM injection M.A. Rakib FLUENT 0 June 13, 2000 09:28
