August 22, 2013, 15:14 |
Error reading the dat file
Amirali
Rep Power: 12 |
Hi Everyone,
Recently I have received a cas and dat file, and I need to run simulations on them. As I try to read the cas and dat file, the cas file is properly opened but I receive error for opening the dat file. I receive the following error: Error: in read_thread_svar! Error object: #f Error reading the dat file. What does this error mean and how should I fix it? Thanks |
August 23, 2013, 03:33 |
rayan
Rep Power: 12 |
Try to read firstly ". Cas" alone then ".dat" separately
April 27, 2017, 00:40 |
Piramanandhan
Hi all,
I too got the same error, when I read case and data files. The answer in this thread was , to read case first separately and then data file. But that doesn't work for me. I found in my case, that the case and data file was different. From this, I came to know that there might be some kind of problem with case and data. Please ensure the case files and data files belongs to same set of analysis. |
dat, error, fluent, object, read |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
[swak4Foam] problem on installing swak4Foam | navid2 | OpenFOAM Community Contributions | 2 | May 30, 2012 04:32 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
