May 5, 2017, 10:11 |
How to import file data to FLUENT
Albert
I have a problem with import solution data to fluent. I have a file, format txt from excel and i would like to import my file to FLUENT.
May 7, 2017, 19:32 |
Lucky
Rep Power: 65 |
If you want to import it as a boundary condition, look up how to do a "PROFILE".
If you want to import it as the initial solution, look into an "interpolate" file. Before v18 these were pretty much the only options, but since v18 was released Fluent supports reading .csv tables as profiles and so on. |
May 13, 2017, 06:48 |
Albert
I would like to import data solutions. I averaged my data in excel and i don't know how to import this data to FLUENT.
May 7, 2019, 05:53 |
import data
Rep Power: 7 |
Hi Forte23,
did you solve this problem? because I have the same constraint in my work. Best regards, SER |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
