April 22, 2017, 05:29 |
Checking convergence
Anil
Rep Power: 9 |
Hello Everybody,
I am kind of new to CFD. I am working on a project where I am doing steady state analysis with K-epsilon realizable model. So since i run many iterations of these kind how will I check whether the solution has converged in Fluent. I set monitors for my output also. But how will I decide that the solution is converged? Please help . Thank you in advance. |
April 22, 2017, 16:53 |
Fernando Avelino
Rep Power: 9 |
It depends on how accurate your project needs to be. If you set a value on residuals monitor and, during the iterations, the residuals reach that value, the solution is converged. Note that the smaller the value you set on residuals monitor, more iterations will be calculated.
April 24, 2017, 11:53 |
#3 | |
Anil
Rep Power: 9 |
If yes, there is one more question I have here. Usually I will put up my case and data files into the server to solve. In this case how can I verify the convergence. Is there any way to write the residual values in a file so that I can verify it later after I retrieve from the server??? Thank you in advance. |
May 4, 2017, 18:54 |
Fernando Avelino
Rep Power: 9 |
In this case, I don't know how exactly to generate a file with residuals data since I run my simulations directly on my machine and check the convergence on the residuals plot showed during the calculations (see attached image).
Maybe one way is to check how many iterations you set and how many the solver used to complete the calculations. Sorry if this seems too obvious but I can't figure now a better answer. Regards. |
May 6, 2017, 04:55 |
#5 | |
Anil
Rep Power: 9 |
May 7, 2017, 15:53 |
Lucky
Rep Power: 65 |
I disagree with the residual concept as a measure of convergence. Residuals are a measure of tolerance and how well the governing equations are satisfied, they don't tell you if the iterative convergence is achieved.
To check iterative convergence, you should monitor raw solution values like pressure, density, temperature, x-velocity, y-velocity, z-velocity and see whether asymptotic convergence is obtained. However, the convergence criteria is up to the user and each user as their own preferences. I.e. many users run 100 iterations and check if their solution is converged, whereas I have a personal preference for monitoring my solution over 10,000 iterations at a minimum in order to determine the amplitude of the low frequency oscillations in the solution. The finer your grid, the higher the likelihood of low frequency oscillations due to non-linearities. So you run it for some "#" number of iterations and get some amplitude. Then you must simply decide if that amplitude is reasonable or not. I.e. how many significant digits do you want it to be converged to? Ultimately however, for a given grid and settings, there's not much you can do to change the result. Hence, you don't necessarily need a criteria defined beforehand. You can simply check the asymptotic behavior and take whatever amplitude comes out in the same way that experimenters accept whatever errors are in their measurement; you simply need to report whatever errors there are. |
May 8, 2017, 06:08 |
#7 | |
Anil
Rep Power: 9 |
May 8, 2017, 08:03 |
Lucky
Rep Power: 65 |
48 +/- 0.5.
May 8, 2017, 08:05 |
#9 |
Anil
Rep Power: 9 |
convergence check, convergence fluent, fluent 16.0, k-epsilon model |
cgns grid problem | praveen | SU2 | 20 | March 10, 2014 14:09 |
[GAMBIT] periodic boundary condition for a rectangular duct domain | Das | ANSYS Meshing & Geometry | 26 | June 5, 2013 07:48 |
[GAMBIT] odel the stirred tank in GAMBIT | jamalf64 | ANSYS Meshing & Geometry | 21 | October 17, 2012 03:16 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 05:49 |
